Thanks, that had crossed my mind too. I think I will give that a go.Diesel... $3 or so for 1/2 gallon at the pump... Heat the barrels, then pour some diesel in.
No, no attempted weld beads yet! That's the evidence of my attempt at knocking off the remnants of the jagged metal from the spark plug with a flat edge. Superficial at this point.Kinda looks like a weld bead top left?????
I think I'd be tempted to take a punch and knock the center electrode and ceramic through into the cylinder, then try an easy out on the plug shell.
+1 for pulling the head.
Pull the motor and the head.
If you started that way, you'd have the plug out by now.
The ceramic drives out EASILY from the combustion side out the top, once the crimp is off, your crimp went with the snapped off plug top.
Cut through the plug body to threads, even a little head aluminum with a little Drexel on one cut, pinch the head/her to break it free. That fails, make a cut 180 degrees to have 2 halls. The kit mentioned in post 48 will open the hole to turn in a threaded sleave.True, but with other projects in the way and nowhere to put the engine, with no space left on my workbench, I really would like to get it out with the engine still in the frame. No worries if it comes to pulling it. This wasn't a planned project but of course, it is now thanks to my inability to control myself!
Look for a timesert kit with a tap like this one. Uses what's left of the existing threads to guide the tap. Much more user friendly.
@Jim That looks like a really well thought out solution.Look for a timesert kit with a tap like this one. Uses what's left of the existing threads to guide the tap. Much more user friendly.
