XStretchified650
Back in the 650 Saddle
While in the process of diagnosing and hopefully fixing a problem with the right side turn signals I checked the voltage coming to the flasher unit. I found that with the key OFF I still had voltage coming to the flasher on the brown lead.
It jumps around a bit but generally reads about 7 to 8 volts. (Key OFF)
With the key On it reads about 12.6 volts.
I tested the brown wire's soldered terminal at the back of the key switch and I get the same reading. (7-8 volts with the Key Off).
In the headlight bucket I unplugged the other brown wires that connect to the brown wire from the ignition switch to make sure that I was isolating the voltage reading to the back of the key switch and I still get the 7-8 volt reading.
I assume that OFF means OFF and the brown wire should read zero volts with the key in the off position.
Please advise.....Is the inside of the switch serviceable?
XStretchified
XStretchified
