No I don't know for sure what's safe on the stock block but I'd guess around 840 or 850. I wonder also if you can just fill that thin area in with a welder and then bore to 880. If you were wondering why mkst guys build 750s not 850s it's because the crank case came cut for 750 sleeves right from the factory. If you want to go bigger than about 81mm pistons the cut out in the case needs to be enlarged.
I don't know what the max stroke you could fit is either but I know machines up around 1000cc have been built. There are a lot of reasons not to go down that road unless you really need to. Craig Weeks has a post on here talking about the things that start to fail if you push the power much over 70 rwhp.
