Good morning, I finally got my project assembled enough to ride so I ripped it down the street a few times.
Initially it gave me a few problems. The right side was starving for fuel and it ran very rich. My fuel line configuration changed because Im using a tank from a Honda, which I believe is the source of the right cylinder being starved. I'm not sure why it was running so rich though. After it warmed up a bit it all seemed to clear up and run fine. The several laps I took around the block went great and it was faster than I expected!
After I turned it of and let it sit I noticed that the carbs were leaking from one of the holes on the face of the intake. Not very fast, maybe a drop every minute or two. Just enough to keep a small spot on the case wet.
Anyways, here are my questions:
Why are the carbs leaking from that particular spot? And
Why is it running so rich on start up?
I was going to chalk it up to the floats but I thought I'd check with you all first.
There's a short video on YouTube that my brother took, if you search "nicks cafe racer" it should be the only one. I was a little long on the clutch
The setup is: 1979 special with stock carbs and open pipes with torque cones. No air filters for the test ride.
