Went through all your threads............A lot of them haven't been finished one wasn't even answered after the 1st post question was asked and a multitude of questions/answers given relating to the content of the question.........
After reading through the threads, i found you have been given so many answers by a lot of different members to the problem your still having........I think you need to go back through all the threads relating to your spark issue and rearrange the answers and explanations as to why, (in some instances), and you might start to get a picture of the problem.............
If threads aren't finished or the OP doesn't respond to answers given then the people who do usually answer and are very knowledgeable don't bother because they feel they are wasting their free advice and time if the OP is not engaging or makes repeated threads about the same problem.........This is just a fact, not coming down on you.............
The warning about keeping the spark plug earthed on a TCI ignition bike,when doing spark testing that it will cause the TCI to burn out is valid but it has to go through the Coil fist and if this shorts then the TCI gets damaged..........Go back to the thread where you ask about burning out your coils.......that was Sep 2017...........In that thread it seems as though you have been using Mikes Ultimate coil the same as the factory one for a TCI and then change it to the Green Monster Coil...............Going back even further to March 2017 the pic of the bike has a Green monster coil on it............
Now if you have been burning out coils since March last year and they have been the Green Monster type then go back and read through your threads and get the answer that was posted about leaving the key on and the effects it has.............especially if a Green monster coil is used.........
Also in your first thread the sparking at the ignition and the use of a battery tender on the bike to test with power without a battery was addressed..........
Answers your getting now are not answers you would get if the whole picture was painted...........
I say reset go back to the beginning and go through your problems what has been answered in relation to those problems and when starting a thread stay on that thread ..............Do a full continuity test of the loom, on the wire before/between couplings/bullet connectors and then through them and again after cleaning and reconnecting....Check all ground connections and clean and reattach...........
