The question is, easier to set up and tune for what? And let's add to the list of Mikunis. If you can do some fabrication, you can bank a pair of Mikuni TM33/8012 or TM36/68 flat slide 4-stroke pumpers or you can split two carbs out of a bank of RS34 or RS36 flat slide 4-stroke pumpers. You can also jet a pair of TM34 flat slides, although, like the VM's, they're not dedicated 4-stroke carbs and represent a rather dated design. In my experience the 4-stroke pumpers are the easiest to dial in because component effects are much more tightly isolated. Run some searches and you'll find plenty of information on all of the above, no point repeating it here.
