Ah! ha, jonboy - first, don't panic.
Drain oil, remove the right cover, unscrew six retaining bolts, remove plates and discs. Undo the 27mm nut, slide each part of the assembly off (usually slide it onto a long screwdriver as it comes off so I can put everything back on in the right order.
And that's it.
BUT - take care not to disturb the kickstart assembly, and make sure you keep all washers, spacers, and the one thin crush bearing in the order they come off - I would video what you do, and hey, what the heck, post it for us to see, and if you need help, we are here.
This is the opportunity to examine the clutch plates and that crush bearing for wear (the plates might look good, but it is a matter of measurement).
When you have adjusted the shifter-shaft, replace the clutch assembly. Careful to torque down to spec. Replace cover (do not forget the kicjstart washer that might have come off stuck on the inside of the cover). Make sure you add copper washers to the lower 5 casing bolts.
Put oil in, and that's about it.
Anlaf
