BigBoreSwede
Hello.
First.....this is a complicated thread because of all the names of all parts in and around the clutch but I´ll try my best
With the whole clutch assembly mounted as it should be I´m able to wiggle the outer drum/ primary drive a little bit. It doesn´t sit tight on the shaft, is that how it should be or have some parts reac there wear limit???
In Haynes I can´t find any spec on wear limits or mesurements on the shaft, washers, bushings and so on.
Hope you all know what I mean
Thanks/BigBoreSwede
Thanks/BigBoreSwede
