Thanx, Yellowdog. That sure does look like a straight, non-beveled edge. And, it looks like plain cast-iron, no edge coating. Factory OEM '256' rings might just fit in there.
If so, then these Cruzinimage '256' piston/ring combos match the originals.
Which makes the MikesXS '256' pistons, with their advertised '447' rings, another/new combo to watch out for.
A lot of our period Honda rings had a practically unnoticable 1/2° to 1-1/2° edge angle on the top ring, forcing the upper part of the compression ring to wear-in/seat first. You could see this upper half wear-in pattern on used rings. That's why they had to be installed with the stamped/marked side upward.
Hopefully, your top/compression rings have this same miniscule edge angle. How's your eyeballcrometers?
