XSFrits
Hello,
This is my first thread. Hope you guys could help me out.
I have bought a new dynamo and regulator at a dutch XS650 webshop. I have problems with getting enough power out of the regulator/dynamo.
I do have spark (dual coils) when I kick it with the battery attached. So Pamco on battery is not the problem. I also have a capacitor/condensator 25v/15000. Is this the problem? but that does not explain the low voltage out of the regulator...or does it?
The people at Powerdynamo asked me to send it to my reseller if I think the material is not working correctly. They cannot help me, because third party (pamco) is involved.
I want to know if you people think the powerdynamo or regulator is not working correctly.
Please help, I am so stuck right now and want to finish off the bike.
Here are a few things i can already tell you:
- I have 0.7 ohm on black stator wires when installed, and also 0.7 ohm when not installed.
- no pinched wires
- no bad smell on regulator
- ac voltage is 5 on black wires when kicking
- dc output regulator 0.2-1.0 volt when kicking
- no burning light when 12v bulb installed directly on regulator
- i see no weird cracks on the coil wires.
- Pamco should work starting with 5volt dc
Do check the photo with the non attached white and red wires coming from the big coil
Does this mean anything? Keep in mind a have a separate timing (pamcopete) on crackshaft. So is this just an optional part for giving voltage to a possible pickup?
- no pinched wires
