New member here looking for some advice.
I bought a new 1971 XS1 650 back in college and road for 5 years so it's been a while. I recently bought a I 1975 XS 650B that I have been restoring. It has been sitting for approximately 20 years with old engine and fork oil, brake fluid and gas. The fellow I bought it from advertised it as is, ran well when parked, not running now, confirmed the engine wasn't seized and that the compression seemed good, it was his father's bike with 10k miles and very clean. I shipped it east and started work on it in mid August.I emptied all fluids, replaced fork seals and oil, replaced master cylinder, flex lines and caliper piston seals, emulsified all rust in the tank and coated with POR 15 tank liner, rebuilt both carbs, new filters, rebuilt petcocks, lubed all cables, sprayed some lube in the cylinders, cranked by hand the 50 x, installed a new battery, gapped and installed new plugs, checked spark (good) and refilled oil and gas. five kicks, it started and idled evenly around 700 rpm for about 4-5 minutes (until the engine heated up). then started misfiring and oil smoking out the tail pipes and a bit of oil smoke off the front face of the cylinders.
Turned the bike off, pulled the plugs and saw they were fouled with oil.
Other than the oil leaking into the cylinders, the engine was running very nicely. My guess is the head gasket is leaking and I should have re-torqued the head bolts before starting. It could also be worn valve guides and/or valve seals. In any case, I have to pull the engine and get into the head and will check valve fit and top end condition but I would welcome any advice on how far to go since I will have the engine out. Focus on the oil leak and any observable wear or do a total engine rebuild)?
Thanks for your thoughts.
Christen
Christen
