re paint yamaha engine side cover logos
Mikey
got muscles in his head that ain't never been used
XS650.com Supporter
Waite Park MN.
I have a nephew who is going to polish up the engine side covers what's a good way to repaint the Yamaha logos black again
Hobby store paint using a brush ?
its a 75 and I like to keep it looking stock
Clean out the old paint with some stripper
then make sure they are fully dried and clean. A shot of brake cleaner removes any last traces.
Mask out the area around all the letters and spray paint them with some engine enamel. Light sprays over a couple of coats as you don’t want to fill the letters you just want to make sure they a fully covered. Then with a rag with some Varsol or paint thinner on it clean off the paint between the letters. Don’t us too much varsol as you do t want it to drip in to the letters. I have even done it using a bit of stripper on the rag. The key is a little goes a long way and be gentle.
It's pretty easy while covers are flat on a bench. Prep is key get all the polish compound in there cleaned out. I just spray rattle can paint into a cap and brush it in heavy, let dry. Use a bit of thinner on a rag to clean up any over the lines booboos.
Once again thanks guys I take it I should remove the paint before polishing
Just a wax job after it's all done (polishing) painting
I scuffed them , painted the lettering with some metallic base with a small paint brush. Then sprayed clear coat over them. I used high quality automotive base and clear coat My tank emblems I used a similar but different process.
