Fleksta
I've buttoned my motor back up but there is an odd noise when it is turned over. Every time it passes the TDC mark it makes a metallic "ping" clearly audible in the video.
I had the motor apart to replace a leaking head gasket, and also replaced the cam chain and rear tensioner. I did no other work; pistons went back in as they came out and I didn't touch the valves.
Once back together I adjusted the tensioner and re-adjusted the valves (which were all very tight). I already checked to make sure the copper washer was still on the tensioner assembly.
I'm wondering if this is something to worry about...or just me being paranoid?
The first ping can be heard at the 4 second mark:
