Hooked up jumper cables to the new bike, and even with carbs pouring gas EVERYWHERE, she runs!...not well, but hopefully a great carb cleaning will take care of that.
There does seem to be some issues from siiting for years unused. First, the clutch seems to be locked up tight. Things roll free in neutral, but not in gear with clutch pulled in. I've read as much as I could find and have tried adjusting the clutch as per the Clyner manual (and instructions here), tying clutch lever pulled and working rear wheel with bike on center stand, trying to roll back back in forth in gear with clutch pulled, and even starting in gear with clutch tied pulled and stupidly trying to keep rear wheel from turning (accident waiting to happen). Anything else to try, or is it time to drain oil and pull clutch apart?
The front brake also seems to be frozen up. It's dragging now, but pulling the lever doesn't do anything. I assume the piston is stuck. Any tricks other that pulling apart caliper and MC for cleaning/rebuild? I read about using compressed air or even grease to move piston when doing rebuild.
Thanks for the help - I've got some catching up to do with my son!
