Lol, I can barely keep track. I try to answer questions best I can in a useful way.
I was looking at one of those lights, they're supposed to be pretty good. I ended up using the modified projector because I wanted a small round light.
*edit*
The mounts for the numberplate were fabricated. The bottom mount is a long aluminum spacer with a 90mm m8 bolt, drilled and tapped lower triple. Upper is sheetmetal I cut and bent to fit my speedometer. The speedometer and light set the distance from the forks.
