I made some comparison measurements of an OEM 502 and the aftermarket 502 using a drill gauge and the depth gauge on my caliper. I did this by inserting the needle into a hole and then measuring how much the needle protrudes from the face of the gauge, I did this using the 1/16, 5/64, 3/32, and 7/64 gauges. In the 3 smaller holes the OEM needle protruded about 0.5 mm more than the aftermarket needle, in the largest hole the aftermarket needle protruded about 0.25mm more than the OEM needle. This would make the aftermarket needle a bit leaner in the lowest range of throttle position and a bit richer everywhere else. This agrees well with my observations, at the settings I was using I had a slight flat spot at part throttle and was a bit rich above that.
