fullercameron
I recently removed a non-functioning starter from my '72 xs2. I want to remove the starter relay as well and I wanted to double check that I am not missing something before I run into trouble.
The relay appears to have 4 wires: Large wire from battery, large wire to starter, two smaller wires - red/white (from ignition?) and blue/white (from decompression lever/start switch). Since I have already removed the starter, I am just trying to figure out if I can just remove the large power wire from the relay and disconnect the two smaller wires.
It looks to me like I can just remove the power from the relay and put a piece of shrink tubing over the end of the boot so it can't touch anything metal (given that the boot would be open on the side where it used to connect to the relay). The large cable would still be connected to the battery, but the power would be fed to the bike through the smaller red wire only.
My main concern is whether or not I need to do something with the two smaller wires. It looks like I shouldn't have any problem just disconnecting them, but I wasn't sure if power fed from the ignition through the starter relay.
I am using a replacement, stock style harness from mike's and the only alteration to the electrical system I have made is to remove the safety relay and the starter.
I have been looking at the wiring diagrams, but since my brain processes the electrical stuff a little slow, I thought I'd run it by the committee before I made my life more difficult. Thanks for any advice.
