whynot2
I have a 1981 XS650H. It is mostly stock. I am attempting to replace the fried starter relay with the MikesXS part # 24-6526. It is NOT a direct replacement. The brackets are very different. Has anyone used this part in a stock setup? How did you attach it?
If not this part, what did you use and where did you get it?
Thanks,
Whynot2
After venting: It looks like I can "adjust the bracket" so that one end can be attached at the original hole. The other end will just be jammed in and vibrating. Still looking for better solution.
Thanks,
Whynot2
