ANLAF
XS650 Guru
That's a good job there, Carbon. I am not an engineer, so how does it work when you've 'stopped' that crack by drilling, and then drilled it out? I take it that preserves the integrity of the metal.
Anlaf
Anlaf
T tell me, will 'stop drill' help me with my window?
Anlaf
Hey, ANLAF, g' mornin' mate. You brits come on board just like the rising sun.
'Stop drill' is an old, proven method to prevent cracks from lengthening/migrating, especially effective on plexiglas. Like the old 'tear the phonebook in half' trick, shear/stress is concentrated at an extremely tiny zone, the very tip/end of the crack. By drilling a hole there, being sure that the end of the crack is drilled out, forces the shear stresses to be distributed over the larger hole edge, and the crack stops progressing...
ANLAF, on the 80 up bikes that had the TCI there are no bushings in the cam. So there is no old bushing to compare to.
On installing the bushes for the Pamco, If you found that it was going in hard I might think to use a Dremel tool with a thin cut off blade and cut a slot in the bushing. Like the bushing for the clutch push rod. This will let the bushing compress to a slip fit. After all the rod won't be spinning in the bushing like it does with the points and advancer.
XSLeo, I'm not sure what you are talking about here. The ATU rod never spun in the bushing ever. It simply rotates the whole assembly at camshaft speeds and the rod rotates in the bushing the amount the ATU advances and retards. That's why a little moly grease every 5 years will make both shaft and bushing last the life of the bike. That statement is just totally wrong.
Anyway Carbon, you are the MAN. Watched your video and hoping you will allow me the privilege to use your idea for bushing removal. Awesome! Never would have thought of that one.
I think the elusive flying object might have been a bronze bushing shard or something left in the extension you were using as a drift.
And the idea of mounting the ATU whether it is needed or not, for those who have the other ignitions systems, supports the cracked shaft and eliminates any further failure.
Good recovery!
Happy Motoring!
...With the ATU it spins a small amount. About 28 degrees...
Peanut - conservatory has shifted. Just inspected, and seen a gap in the roof panels. Oh! my - quick, insurance claim before the first fall of snow and the grizzly bears start their prowling.
Anlaf
I didn't know there was a Labyrinth Seal
The kit for 80s-84 only comes with 3 bushes .
the directions say to put 2 bushes into the right side of the cam.
And only one bush in the left side which leaves room for the Labyrinth Seal
Right now there is a space and the advance rod rides only a few MMs of the bush.
Looking at the cam for my #1 engine is has bushes and Labyrinth Seals, one of each in both ends.
So what does the Labyrinth Seal do in this case the bush does not?
is it just wider?
Is see on the other cam the Labyrinth Seals come out to the edge of the cam.
Two bushes together don't quite make it to the end.
A guy would think the Pamco kit would come with the correct parts.
