I have a small job on the go to replace my headlight and headlight ears. I removed the forks and now I'm wondering about the proper torque for the lower fork pinch bolts.
My Haynes manual says 8 ft-lbs for the upper pinch bolts and 14.5 ft-lbs for the lower pinch bolts. These bolts are all the same size at 6 mm, so I agree with the 8 for the upper, but the 14.5 seems to be rather high for the lower. What torque are you lads using for the lower pinch bolts?
I see that for the XS650D they specified 6 to 9 ft-lbs, and then for the XS650E they moved up to 11 ft-lbs, finally going to 14.5 for the later years.
