angus67
Welder's penetrate deeper!!
oh.... that makes more sense.
So if I buy the e-adv. do I have to get the 60* wheel?
thank you. Im gonna hit a couple of second hand stores, and see if I can find a stereo that would have those wheels for the needle thread.Yes, you will need the 60° rotor to use the E-advance.
...It feels like it's surging ...
... When I checked the timing, it was just tad left of the t mark, and it flutters about. ...
... I checked timing while dragging a screwdriver handle on the disk to take out slop. Same flutter, maybe worse, so I didn't shim it...
How do I time it at full advance at the t mark? There is something im missing here. When I do idle timing, the line on the rotor flutters just left of the t mark. When I rev to full advance, it goes no further than the left most mark. Should I back off timing even more so at full advance, it is just right of full advance mark? I think I tried that some years ago, and kept shutting down...
... Interesting psa. I have a pair of 76-77(?) 38's I could slap on there and see if the stutter goes away. The 38's on it now are presumably the originals with the elevated floor, and say solex on the top. One thing I noticed when I did the dead cylinder idle drop, when they both end up running their best together, one mix screw is one full turn out, the other, 3/4 out. don't know if that matters, its basically just taking what it needs, regardless of what the other cylinder needs.
...As far as the advance rod, how do you fix 'angular' slop?
... low and behold, No o-ring, and no washer in the idle screw bore.
Runs WAY better now.
Thanks guys, especially two many, your thought on the idle mix screw being way off made me look closer at that area.
