sgallaty
Antihero
I don't think the oil was ever changed. Yes, I bought the bike on a gamble thinking that the internals of the engine had a good chance of being solid.
The key is going to be the cylinders. I'm about to pull the engine and find out.
EDIT:
Also, I can't find my impact screwdriver. I guess it was in the junk I left behind when I moved.
The hondas I used to work on had those shallow cut japanese philips head screws holding everything together. You get really good at taking out philips head screws - so the few philips heads I've run into so far have not stood a chance against me.
Compared to a CB750 whose side covers are recessed philips heads (you can't get a normal impact hammer bit on them), this bike has been cake. I did have one apparently stripped side cover bolt, but it looks like someone just tried to drive a 20mm bolt into an 8mm deep hole.
I did have 4-5 philips heads inside the case (on the stator for instance) and two on the carbs that I had to employ dirty tactics to remove. I hit them up with pb blaster, let them soak a bit and then put a philips head screwdriver in the screw and hammered on it a little (black magic for loosening up philips heads) then clamped a vice grips on the head very hard, and turned them. You pretty much only get one shot at it, because if the grips slip you'll end up tearing the head of the screw up and they may not grip again.
They all came out, some with a little more reluctance than the others. The screws in my alternator housing were solid blobs of rust.
EDIT:
