UK Brat Build (Engine first)
Got the casings and barrels back today. The barrels are left bare aluminium and the casings and head have been power coated gun metal grey.
Working off the Christmas pud, a little work today, mainly preparatory. The powder coating process has let a little coating onto some areas, whilst not machined faces, definitely those need to be perfectly flat. For example the cylinder head stud facings.
So, I decided to machine all those surfaces flat and get the Dremel out and ensure that any excess or interfering coatings were removed.
A bit of time spent restoring the tappet cover studs was well spent. Years of abuse and the powder coating took their toll.
A bit of a before and after
Popped the rockers back in but not before a good clean on the wire wheel and some fresh oil to bed them in
While the Dremel was out, I gave the cylinder head a final clean and polish and a final valve lapping, ready to go back together tomorrow
.....and all the parts are starting to assemble
A bit more progress today. I started on the head and noticed that from the factory, there is a significant lip that is present on the inlet ports. So, with my new Dremel, I ground out some material to give the charge a smoother passage on its way in.
...and after
After a good clean out, I reinstalled the valves, springs and collets along with new valve stem oil seals
I’m waiting now for a new set of stainless bolts for the cases and head. So.... I thought I would put together the hydraulic clutch. It’s a slave cylinder from an Aprilia which has a mount that's almost the right dimensions to fit into the aperture left by the original worm gear.
First we have to remove its legs and machine it true
Then to mark up the holes, drill and tap to M6.
.... and we’re done for now. I’ll need to measure up for a new pushrod but I’ll do that once the engine is back together.
A little clean up and tidy for the cam chain adjuster mechanism too..
After.....
I noticed there was a little spacer / spring retainer missing, so I machined one up
Thanks Mailman! I could actually get stuck into a full build but I have no space. Never mind, the engine will do for now...
I will have quite a bit of machining work to do after the build, so there’s plenty to do. I noticed certain parts like the sump plugs, neutral indent, rocker caps etc are all steel. I am planning to machine all of these out of aluminium. I’ll have to remember to weigh everything before and after
Sump plug in Aluminum I would Advice against that ---this is a rather large ( if it is the 2 I believe ) plug and needs a high torque if copper washer is there.
And the plug goes in and out every season
And when ( if ) the head gets round it can be difficult getting --- Out
Vice will only deform it more .. As will trying to cut a slot for a screwdriver.
I did this on a Honda Fireblade last summer.
Tried a torch.
It was close that i needed to take down the sump. To Drill it out
Which for XS650 perhaps is simpler.
I Managed to solve it drilling a perpendicular hole in . The damaged head.
Inserting a Philips Screwdriver in the hole and hitting on the screwdriver with a hammer.
So it popped loose.
At least those steel plugs can sit really hard.
I’ve not taken a photo of the pistons & rocker shaft plugs yet but then it wouldn’t be the most exciting so maybe we’re not missing much?
Very cool indeed! Unfortunately, I don't have access to any titanium, so I'll just have to make do with alluminium!
Tried a torch.
So it popped loose.
Hi Jan P,
Yes, I know where you are coming from, with regards to the aluminium sump plugs. In this case, I plan to use fibre washers and the torque value won't be that high. I have changed to aluminium several times in the past and most race bikes I have had, were all fitted with aluminium sump plugs.
So, I'm confident all will be well.... there's only one way to find out :)
Enjoying watching this one. Huge progress already, given the state of the engine when you got it. Mole grip marks on the cylinder studs attest to the, uhm, mechanical abilities of POs.
Hi,
Thank you! Yes, very much so, I noticed that... along with everything else as I stripped the engine. A big fan of bathroom silicone too ;)
Hi,
OMG Bathroom silicone! A few years ago, rebuilt a 1970 Triumph TR6 650 twin. QD rear hub. Except it wasn't quickly detachable because PO had practically filled it with white bathroom silicone. I could not believe how much I removed once I got the halves apart. An attempt to reduce free play, methinks?
