HI
I most probably have a small leak in the float valve, due to old stuff or bad adjusting. It doesn't leak right after switching off the engine, but after one night it has leaked from both chambers.
Would it be possible to work on the float valves up side down, just removing the float valve cover? SO that i don't have to remove the carbs. To inspect and remove possible old stuff or adjust the the float valves.
/Martin
/Martin
