My three-phase regulator is also a cheap one. $10 or less.Just use a gy6 regulator to match the stator.
Thanks for watching. Actually I only assembled the spokes to test the length of the spokes, I haven't assembled the wheel yet.I believe your spoke pattern is wrong at some places
Nearest to the hub.
If you look at 8 o clock 4 spokes crossing
9 o clock the same
but 10 o clock looks different
I have never done a Motorcycle wheel but bicycles ..and if the spokes are not going to the right place the nut can bottom out
since the length sticking out differs
If that picture is the final setting
Perhaps not the answer to your question .
I thought the same and check the bearings well.Are bearings fully seated against clean recesses? Cocked bearing , first guess.
I found the problem. bad seals.
That might be the pavement.Notice a bit of bouncing on the freeway
