larksnostril
Charlie
I'm considering a permanet magnet alternator for my '81 Special.
Has anyone had experience or direct knowledge about this product
http://www.xscharge.com/#!
We offer the most complete kit at the best price on the market at only $289.00. Our parts are specifically built to our specifications. Our adapter bracket is hands down the easiest to use and best bracket available. We have the strongest rotor on the market to help with low RPM charging. The rotor hub is made to our specs with the correct keyway so there is no filing or guess work in getting the correct fit to the crankshaft. We have a plug and play voltage regulator with a battery side quick disconnect. The kit also includes a laser cut voltage regulator mounting bracket that bolts to the rear upper motor mount bolts. Everything you need including all new hardware and step by step instructions is included in the kit. Just click on the tab marked "OUR STUFF" to purchase this kit.
Lookin for advice from guys wiser than me about this stuff...THANKS!!!
