danfr
Hey guys,
I have a new to me 1978 XS650 Special. I couldn't for the life of me get the clutch to disengage. I removed the clutch cover and found tie wire between a friction plate and steel plate!
So I completely disassembled the unit, and am about to reassemble the clutch with a set of used steel plates that I sanded down (the steel plates that were in there, had some serious heat marks).
The problem is that I noticed my clutch assembly completely different than what should be on my 78.
I did find the proper exploded diagram to what I have in my XS but now I'm having trouble getting everything back together in the right order. I'm hoping someone can confirm my order:
Installing into the basket..
1)Smaller ring first. Smaller being that it has a smaller O.D. It also has a lip. Like an L-shape profile and the L facing out (flat side facing in)
2)Cupped steel ring. Small diameter of ring facing in, large diameter out
3)1st steel plate with the teeth that engage the inner clutch hub (or whatever it is called)
4)Skinny wire, cir clip thingy.
5 and onwards) normal stacking sequence of clutch.
I also had a washer fall out when I removed the clutch cover. Is there a washer between the cir clip for the kickstarted and the outer clutch cover?
Cheers Dan
Cheers Dan
