Now, I wanted a nice flat end on each fender. First I used the flap disc to smooth out the ends, then I busted out my block sanders that I bought years ago for a DIY car paint project that never came to fruition. Finally a use for them. I used 60 grit and wet sanded. Of course, the sanding area is so small that wet sanding was over kill and not that important, but I did it anyway. It helped to wash off the sanding bits and keep my template line in clear sight. I turned out pretty well. I used the angle grinder to trim the inside lip so that it would not be so visible from the front. The other side ended being a bit shorter than the other side because of the hole in the fender, which meant I had to cut it to the line to clear most of the hole. No matter, I will use the longer side towards the rear to keep as much water from splashing the engine as possible. The second side's corners are more round than the first, so I spent some time rounding off the other corners as well.
Since I am going to have a polished steel gas tank, I need to make the fender match. Unfortunately, the fender has dings in it, but since I don't have the luxury of painting it like originally planned, I need to make do. I used that abrasive sanding wheel to give it a brushed look. Since the fender seems to be an alloy, there are some weird markings underneath the brushed surface. I experimented with orbital sander and angle grinder on spare parts to see if I could shave down to that level, but nothing came out right, so I left the fenders as is. It doesn't look bad, and I will eventually paint it anyway one day.... Oh yeah, I also used a scuff pad to smooth it over as well.
