cmyoch
XS650 Junkie
I'm sure there are more posts out there like mine, I haven't seen much to help so I'm going to post the questions again. I just put on 20 initial miles since my top end overhaul. My plan was to warm it up really well, let her cool down tonight, then retorque the head nuts. I noticed at the stop signs that I was smelling oil burning off the block. I brought it home and saw that my entire right side was pretty wet with oil. The valve covers looked pretty clean around them but the advance unit had oil droplets below them. The engine was too hot for me to remove the cover to inspect. I have the fresh gasket set from MMM on my bike and I know I put fresh seals on the cam covers. I'll pull the advance unit and inspect around the rubber seal to see if that may be the culprit. I read somewhere someone suggested taking a scotch brite pad or some steel wool to the advance end of the advance rod to smooth any imperfections. Hopefully that will be an easy fix. It seemed like a fair amount of oil that was on the block. Other than the leak, my break in ride was fantastic. I kept the rpms at and below 3k the entire ride and there was plenty of power. I think I'm going to be pretty pleased once I solve the oil leak issue and get my carbs synced and dialed in.
