While waiting for seals and gaskets to arrive I thought I would finish up my oil filter by adding a magnet. Bought a three pack of 25mm x 3mm round neodymium magnets from eBay. Pretty straight forward process: 1" diameter end mill to 3mm depth but instead of just JB welding it in place I added an 8-32 flat head screw as insurance it stays put.
Drill, tap and counter sink so the head is flush with the surface. I did seat the screw in a bit of JB weld to make sure it stays put and because it is a thru hole into the oil passage to seal things off.
Added JB to the circumference of the spot face to hold and seal the magnet.
Last thing was to drill bolt heads so they can be safety wired.
