1974jh5
Curmudgeon.
Ashaman, it just takes practice. The first step is overcoming fear of the front brake and that's where practicing braking on hard pack clay or etc will really help. You get a feel for just how much 'squeeze' it takes to accomplish a certain amount of braking and how it feels when you are on the edge of skidding the tire.
Once you learn that on a slick surface, if you are on asphalt it's not real likely that you will encounter the same thing. BUT- and this is the important part- your brain will remember what it feels like and what to do if it does occur. This raises your confidence a bunch. That's why Kenny Roberts used that training method.
After that initial steep learning curve, learning how to apply in a corner is easy.
The other thing is line selection. Scott Summers used to say SIPE: Scan, Identify, Plan, Execute.
Scan the trail ahead
Identify possible obstacles or problems
Plan how to handle that obstacle
Execute the plan.
It works on asphalt as well as on dirt. For instance, if you see loose gravel or broken pavement in a turn be aware of it and have a plan in place.
Execute the plan.
