nb1914
Hi all,
Just a quick confidence check before splashing out, ok so my bike has been dying. I checked the battery voltage 11.3 which i know is no good. I charged the battery over night unto 13.5V then i left it over night and it went down to 12.6 then after leaving again for a day it went to 12.4/12.3. Im not sure how to check the charging circuit so i simply started her up ( battery now at 11.6v when running) and with a multimeter on the battery reved her a bit and i saw the voltage increase by approx .2v. In my mind the battery shouldn't drop voltage that much overnight (its the original from when i bought it ) and as i see some voltage increase when running is the charging circuit ok ?. I have converted the charging circuit with the nylon bolts and have fitted a modern combined reg/rec. Any thoughts welcome.
