badassjamie
Blow Me
Picked up a 73 for a song, and the more I dig into it, the more issues I find. Go figure.
The starter was not engaging and made the usual terrible whining sound so I take of the right side cover to make the bendix #4 gear clip adjustment.
Now, as I'm in there, I found the previous owner must have pryed on the case against the clip because the nub where the clip return fits into, was completely sheered of the case. As in, broken completely off, explaining why the starter would not work. It just spins freely and useless in there forever. What a shame. I don't forsee this barn find engine going out to an aluminum welding for internal operation repairs any time soon.
No solution here except for going kick only. Okay, guess I'm going to have to live with that.
So, while I'm in there, I removed the clutch plates and then I find the 27mm clutch basket nut had also been severely damaged, looks like someone was trying to chissel it off and it's all worn with shredded edges all over.
Clearly, someone didn't have the right tools and know how to be in there in the first place.
Can't believe my luck here. I can't fit a socket on it because it's so damaged and I tried going larger size with no luck.
I thought maybe trying to get a small die grinder in there to trying and grind down the edges some so I can at least get a socket to go around it, but I don't have one.
What would be your idea for trying to get that off for a replacement?
