Crashedkiwi
Well I have to ask for the great wisdom of the group again. I rebuilt my xs650 xs650B (actually was a box of messy bits, but that is another story) into a "cafe racer" for want of a better description.
The engine shows reasonable compressions at 150/ side, the head and valves were professionally cut and seated and a new timing chain fitted. I've fitted VM34 carbies ex Mikes XS and they are jetted as they came. I've also fitted Tri spark ignition and a MIkes XS stator/rotor kit. Tank is clean, sealed and fuel is good.
When I first finished it, the bike started and ran and I rode it around this city satisfactorily for a number of weeks and then it just went temperamental on me and then would not start.
I've now gone slightly mad trying to figure out why. I've checked and reset the cam chain tension, valve clearances and reset the ignition timing. I've de-mounted and checked the carbies for blockages etc & checked the float levels. Spark is fine and plugs are new Iridium ones - I've even taken the complete ignition system off and installed it on my other XS and it runs perfectly.
The bike turns over sometimes part fires, but does not start. When I first assembled it , it started first turn and ran smoothly.
any suggestions as to why I cannot get it to run gratefully received.
