Rexxis
Almost there...
I ordered a set of carb boots from Ebay and they ended up not fitting my carbs.
I learned today that my carbs are from '76-'77, not '78-'79 like I thought. The ones I ordered said they would fit years '78-'83umm. Here's the jump to the ad:
http://www.ebay.com/itm/360477327566?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Did the bore sizes change between '77 and '78? If not, then the '78-'79 boots should work fine on '76-'77 carbs.
OD on my carbs where the boots sit is 46mm, ID of the boots I received is 42mm.
Seller is claiming I ordered wrong boots for my carb and that I received the correct items as per my order, which may be the case but I hope not..
Help me out here, Thanks
Boots
My carbs, '76-'77 yes?
Boots
