The great o-ring, seal, gasket, nut, bolt, sizes used on the XS650 thread.
From an excellent 5twins thread here; https://www.xs650.com/threads/suzuki-carb-parts-for-our-650-carbs.61197
A couple of these have been mentioned before, the butterfly shaft seals and the brass floats for the 1980 BS34s .....
..... but I've discovered some others and would like to share. Here's a Suzuki parts diagram from Part Shark showing most of them .....
Part #16 is, of course, the butterfly shaft seal. At around $1.50, it's quite the bargain especially since Yamaha's price recently spiked big time, more than tripling from a retail of $5.99 to $18.50. Even discounted from Partzilla or Part Shark, you'd still have to give $12 to $14 for one. The next two parts on the list, #17 and #18, are pure "unobtainium" from Yamaha, they don't even show or list them. #17, what Suzuki calls a "Gasket", is actually the plastic washer you'll find on the BS34 butterfly shafts. I was delighted to find this part as they are often pretty beat up and in need of replacement .....
Part #18 is the e-clip fitted on the outside end of the right BS34's butterfly shaft, another part I was delighted to find. They are often pretty crusty and rusty. Here's one compared to an original and it is, indeed, an exact match .....
Part #26, the float bowl gasket, may seem expensive at a bit over $6, but it's not compared to Yamaha's $38 retail price. Part #28, the rubber plug for the pilot jet, is also a few dollars cheaper from Suzuki. But both of these parts can be found cheaper from the aftermarket on eBay.
Part #34, the retaining plate for the BS34 float needle seat, I sort of struck out on. Usually, when you look a part up on Partzilla, they have a picture of it. For this one they didn't, so I just went by the drawing, and it let me down, lol. Here's what the part really looks like .....
But even though there was no way it would fit with the extra tab on the side, at least the cutout and mounting hole matched .....
So, I was able to cut it down and make it fit pretty easily .....
But, I wasn't giving up on finding this part yet, lol. There were several others offered that did show pictures in their listing, and this one looked to be a match compared to an original I measured, just under 5/8" long .....
..... and it is, matching up and fitting perfectly .....
Next up on the list, replacement plastic floats for the BS34s. From researching, I figured these had to be the ones, but the only way to know for sure was to buy some. On a recent 1980 BS34 refurb, the original brass floats were shot from sitting coated in gas varnish for 20+ years. It had eaten holes in them and they failed the hot water dip test. I recommended the guy switch to the plastic floats as they can't do that since they're a solid plastic foam. Basically, they should never go bad. Plus, they're a couple dollars cheaper than the brass replacements. And we have a winner. These are the same float, an exact match in every respect. Here's one compared to an original .....
One of the things you look for in a replacement plastic float is whether or not the pivot pin hole has a tube sleeve insert .....
Many aftermarket ones do not and that makes for a sloppy, loose fit on the pivot pin. The float can hang up and stick in operation, and often does. The Suzuki float has the tube insert so it's good .....
And last on the list, #37, is the float hinge pin, and I quite like this one. Much cheaper than the Yamaha one and , in my opinion, it's better .....
The Yamaha pin is stepped up under the head and won't insert fully. You need to tap it in with a small hammer to get it fully installed. This can make it difficult to remove, running the risk of breaking a pivot post off .....
The Suzuki pin isn't like that, not stepped out under the head much, if at all. It easily inserts nearly all the way, then a couple gentle taps with a small hammer seats it fully and "sticks" it in place .....
But even if it didn't "stick" in there, there's no worries about it backing out. When you install the float bowl, the pin and posts fit into this area .....
..... and that effectively blocks the pin in so it can't back out.
Well, it's finally happened, working on a set of BS38s I needed new floats. Getting them from Yamaha is out of the question as they cost over $40 and even the Suzuki equivalent isn't very good (just under $30). Up until now, best price was about $18 from 650Central. So, I did some research. These floats don't look like anything special, no special shape or odd tabs on the brackets, so I looked for basic replacement Mikuni floats. A very common one that popped up was the VM24/171. Mikuni says it was used on many of the VM type carbs in the '70s, along with many other carbs. One seller was nice enough to show a dimensioned pic .....
I compared it to an original float and it matched, so I decided to take a chance and order some. Now that I have them, I can confirm that they are indeed an exact match in every respect and fit perfectly. Best part is the price - the retail is only a bit over $14. You can buy them all day long on eBay for between $13 and $14, and get them for as little as $11 to $12 from some of the big box stores .....
I'm Replying to this thread so maybe it ranks higher in the algorithm. I was searching for info on BS34 Throttle Plate Seals and found in the Technical Reference page a section for "Throttle Shaft Seals (Butterfly Seals). I sifted through that thread and came up with what I thought I should order but I ran it by @gggGary who pointed me to "The Great O-Ring, Seal..." thread which has up to date info on the O-Rings needed for the BS series Throttle Shafts. The info in the "The Great O-Ring, Seal..." seems to be the most recent and preferred O-Rings for this application. Maybe it will save someone in the future some search time.
When I got my bike, it had a plastic cover over the clutch adjustment hole. It rattled and drove me crazy. Two of them rattled their way out of the hole, never to be found again. I found a metal cap but even if I spread the tabs out a bit it still wasn’t a snug fit. I thought an oring would be the answer. I looked for one for a bit but couldn’t find one thin enough (that was readily available). Then I lucked out. While rebuilding my petcocks I discovered the diamond shaped seal for the petcock base to tank was the perfect size. Stretched over the cap and snapped in place, the cap rattles no more..
I edited that tech post to cover the updated "group think" thnx for the heads up.
We've discovered an even cheaper source for the butterfly shaft seals. Details and a link are in this thread .....
https://www.xs650.com/threads/source-for-carb-shaft-seals.67726/
They are genuine Mikuni seals, sold under the Mikuni part number (BDC36/325). I never knew this Mikuni part number before, lol. I ordered some and they are indeed an exact match to our seals, but with shipping charges, they're only cheaper if you order a bunch (like a dozen).
Wow! good find! Book marked that one!
From @RustiePyles recent post
A list of bolts by dimensions for stator and primary cover (engine side covers) on an XS650
DIAMETER X LENGTH-QTY
M5x12-2
M6x25-11
M6x40-3
M6x75-4
Copper washers
M6-4, get more, use them along bottom of RH cover and the oil filter cover (in spite of what 5T sez) :sneaky:
I'm seeing all these copper washers which one to use along bottom of RH cover and the oil filter cover
https://www.mcmaster.com/products/washers/screw-size~m6/sealing-washers
For Screw
Size
ID,
mm
OD,
mm
Thk., mmSpecs.
Met
Pkg.
Qty.
Pkg.
Copper
M66.2009.9000.8 to 1.2DIN 76032597725A100$13.17
M66.20011.9000.8 to 1.2DIN 76032597725A11410.83
M66.20012.4001.3 to 1.7DIN 76032597725A52013.83
For Screw
Size
ID,
mm
OD,
mm
Thk., mmSpecs.
Met
Pkg.
Qty.
Pkg
For Screw
Size
ID,
mm
OD,
mm
Thk., mmSpecs.
Met
Pkg.
Qty.
Pkg.
Copper
None of those?
M6 by 10mm OD
https://ebay.us/m/jPf5XP
Thank you!!
And at that price for 100 there dirt cheap too
Looking at OEM they were $5 and up for 1
In case anyone like me needs to know the quantity and length of the bolts for the clutch cover:
As I was taking the engine apart 3 years ago, I segregated groups of components. Sadly, after 2 moves in those three years, I cannot find said group of bolts. I did some research and found a parts diagram and a part number decoding thingy (both found on this site), and borrowed one each of 75mm, 40mm, and 25mm long M6x1.0 bolts from work and got it all sorted out. I can buy all these from Ace Hardware, and I have a stash of copper washers I'd made years ago.
