TXterror
$2,000
$2,000
Full Circle Racing Products makes a alloy tank to fit the XS650 frame for street trackers.
I meant that tank lol
$950.00
$950.00
YOU CAN CHECK OUT MY BUILD THREAD HERE: https://www.xs650.com/threads/welsh-flat-track-revival.60449/just had a look and that’s a beautiful Machine you have. Tank fits nicely.
You’re gonna have to come up with the C cups and weld them on.how would I go about putting on a tank that requires the c cup mounts?
It would be to form the "C" with a hammer, vice and hacksaw. Find metal stock roughly 0.090-0I’ve been looking at gas tanks and not sure what will work and what will not. I basically want something that will line up with the seat. Any recommendations? Also how would I go about putting on a tank that requires the c cup mounts? my bike doesn’t have them and currently has a sportster tank.
Theres three different shaped stock 650 tanks out there you could use.I’ve been looking at gas tanks and not sure what will work and what will not. I basically want something that will line up with the seat. Any recommendations? Also how would I go about putting on a tank that requires the c cup mounts? my bike doesn’t have them and currently has a sportster tank.
Appreciate the infoTheres three different shaped stock 650 tanks out there you could use.
1) The early original badge style which look really cool, but are a little longer at the rear mounting point and you have to bend or remove some tabs under the tank for clearance.
2) Mid year Standard tanks which fit the fwd cups and rear mounts on Specials just fine. You can spot one by its center mounted filler neck, non badged smooth sides. These are a little larger and rounder than a true "Special" tank.
3) The "Special" tank. Its very slender and svelt looking, filler neck is off to the right side a little, but it still looks kind of chopper/customish like the Sportster tank unless you do some disguising of it (in my opinion of course). You can fill in the badge mounts with body filler and paint these to look really good on a Street Tracker...I've been looking at many, many examples myself as of late.
Thanks, don’t have a welder and was assuming this was going to be case. Was thinking of putting the rubber stoppers on the frame and find a tank with the cups. Like the Honda tanksIt would be to form the "C" with a hammer, vice and hacksaw. Find metal stock roughly 0.090-0
125", hammer out a "C" then cut it off and repeat. Weld these to your steering neck. With the tank wearing pliable rubber donuts/bushings precision needed is probably only +/- 0125"
There are a lot of cool shaped Honda tanks that have the C cup on them, then you could easily bolt the rubber donuts to the frame, yes.Thanks, don’t have a welder and was assuming this was going to be case. Was thinking of putting the rubber stoppers on the frame and find a tank with the cups. Like the Honda tanks
I don't have a welder either. I looked into hourly or daily rental last year and was not put-off by the $. However, chatting around a fellow who lives near by, went to school with one of my brothers offered me the use of his portable and the use of his band saw in his basement shop. He was thrilled when I returned it with extra consumables and an Auto Darkening shield.Thanks, don’t have a welder and was assuming this was going to be case. Was thinking of putting the rubber stoppers on the frame and find a tank with the cups. Like the Honda tanks
I have a buddy that works in fabrication. I sure he has some buddies that wouldn’t mind. Just wanted to see if there was a direct bolt on option. He’s not the easiest to get a hold of.I don't have a welder either. I looked into hourly or daily rental last year and was not put-off by the $. However, chatting around a fellow who lives near by, went to school with one of my brothers offered me the use of his portable and the use of his band saw in his basement shop. He was thrilled when I returned it with extra consumables and an Auto Darkening shield.
It is currently in my garage again to kickstand extensions.
XS750 has cups on the tank. It's also big. It does fit the XS650.Thanks, don’t have a welder and was assuming this was going to be case. Was thinking of putting the rubber stoppers on the frame and find a tank with the cups. Like the Honda tanks
These make great looking "Cafe" style bikes for sure.XS750 has cups on the tank. It's also big. It does fit the XS650.
