Muckroot
Hello,
I have a set of forks I'm trying to rebuild and I've got a bit of a quandary. I purchased this set of forks with my XS650 under the assumption that they were XS650 forks but that does not appear to be the case! 5twins suggested in another thread that they may be from an XS500 given that the top caps secure with a circular wire clip instead of the screw in socket style cap, as well as the forks sporting what appears to be an 18" wheel. I've got a few more pictures and was able to get one of the forks apart with surprisingly just a couple Allen wrenches, a screwdriver, a knife, and a pair of needle nose pliers.
First, here's the forks semi-complete, with just the top triple tree removed:
Next, some shots of the rim:
some of the info from the brake caliper:
And most importantly, the forks themselves:
something I found very interesting is that there is no receiver for any kind of tool to hold the top of the dampening rod stationary while the bottom bolt is screwed in during reassembly (sorry for butchering the terms) Here is the top of the dampening rod, where on a set of 650 forks a big Allen bolt would fit in. It's completely smooth.
And lastly, the fork seal:
Here's what I need to know:
what do these forks go to?
where can I buy new seals and wipers for them?
are there any other parts that I should service in the forks while they're apart?
what is the correct fork oil capacity for these forks?
is a 650 brake caliper compatible with these forks or do I need to rebuild the caliper that came with it them? how can I measure the bearing rod(?) to find neck bearings that will fit these forks and the XS650 neck?
Also, how do I get the fork seals out? I beat the one up pretty good trying to remove it but had no luck. any advice is welcome.
Best, Muckroot
Best, Muckroot
