The horn assembly? Normally I take pictures when I take stuff apart for this reason. However, with the adjustment screw removed first then removing the screws to the cover caused the contents to come out a bit more haphazardly than I anticipated.
I have looked and looked but can't seem to find the order of assembly to the stock horn 77D.
I went through a few different options. Yes I am getting power. I did clean the points. I get a buzz, but when I put the cover on( screwed down into place), I don't. Does anyone know the order of the internals?
I have power and a buzz when I do the following. From bottom to top ( top being inside the housing or the bolt with the post on it) The black small bell shaped piece (where the adjustment nut holds) two washers, Large black disc, washer with paper gasket then smallest black washer (has two notches that seem to fit into the cross pattern on the housing bolt).
My thought is that the smaller bell shaped disc on the bottom is hitting the edges of the cover preventing it from vibrating. So, moving one washer to the other side of the large black disc would move the bell shaped disc further away from the cover. However; I tried that and did not get any results.
So, anyone the order of assembly?
