54inches
Vagitarian
Awesome FN story and love the fact that you have pics of the unveil. Way FN cool!!!!
Good Luck!
Good Luck!
As well I use I use WD40 as a primer for the first coat of chassis paint on frames, and anything else I paint. It makes the first coat flow on smooth and following coats smoother. Just sand the swingarm down smooth then spray liberally, wipe down lightly and apply the first coat right after.
Goodness !!Here is an Alfa Romeo 2.0 HC Piston I just cleaned up...
Check the brass in the kit and make sure that it's the correct stuff. Hope you are also replacing the throttle shaft seals.I have a rebuild kit on hand, and am not worried about the job
I'm not a big fan of painted carbs. Prefer the natural aluminum look. But if you are doing a true restoration then they need to be how they came from the factory.Opinions on:
1/ Blasting and leaving the satin Aluminum.
2/ Blasting and repainting black.
