pamcopete
Ride.Enjoy.Life is Simple
OK. Here is a technique to do a leak down test without a leak down tester...
1. You will need a compressor with a built in adjustable regulator.
2. Allow the compressor to run until it has reached its maximum pressure, typically 100 PSI.
3. Adjust the regulator for a pressure of 50 PSI.
4. Get an adapter hose that will fit into a spark plug hole on one end and your compressor hose coupler on the other.
5. Warm up the engine, shut it off and remove a spark plug.
6. Rotate the engine to TDC on the compression stroke.
7. Screw the adapter hose into the spark plug hole.
8. With the compressor adjusted regulator adjusted for 50 PSI, quickly connect the adapter hose to the hose coupler from the compressor.
9. Note the pressure reading on the regulator gage.
Note: You must record the regulator pressure before the air tank pressure goes below 50 PSI.
In the example shown, the regulator pressure is 35 PSI, so the percent leak down is 50-35 = 15 / 50 = 30%. Generally, a leak down percentage up to 40% is acceptable. I did this test again with a warmed up engine and got a regulator pressure of 40 PSI for a leak down % of 20%, so warming up the engine is important. However, doing a cold leak down followed by a warm leak down can provide a better picture of the cylinders condition.
