Well, it sure looks nice and clean Raymond!
Pete
Pete
The regulators do not get excessively hot. Best to have free movement of air around them.
Bit of a hiatus today - pulled me abs so hardly able to move. Dare not bend from the waist. And laughing is out of the question.
But did have a play with mounting the reg. Due to the lock-down, have to rely on what happens to be lying around. But that's my preferred methodology anyway.
An old plastic number plate was sacrificed. Cut a piece the size and shape of the 'old' regulator, peeled the coloured backing off, drilled it to take the rubber isolators, drilled to take screws to hold the new regulator plus an earth wire:
Test mounted on the battery tray. Reg has to be set at a jaunty angle to leave sufficient un-drilled plastic between the various holes, see? But by luck, this also means the earth wire avoids the projecting tool box:
And it even clears the side panel, which had occurred to me as a possible problem.
So as far as I'm concerned, job's a good 'un.
