Need some help with stuck wheel bearing - the old one I was using to seat the new one
JayR
CT
I was following the steps from a thread on rear wheel bearing replacement. I Was doing OK until I got to the step to use the old large bearing to seat the new large bearing.
The problem is that I can't get the old bearing out now. The thread I was reading said to remove it with a vice-grips and pulling and tugging.
But - it won't budge.
Other than punching out the new bearings and starting over (damaging new bearings) does anyone have any advice on how to get the old bearing out?
Lesson learned - should have bought the bearing seating tool.
Thanks for any thoughts you may have....
Thanks 2 Many. I had to pound it out from the other end. Need new bearings. Was a disaster from the start, All Balls sent me the wrong grease seal for the small bearing and had to mangle that back out too. Spent hours reading up on it. Oh well I'll get it done the next time :
I will caution to not use the old large bearing to drive home the new one as recommended in post #23 of this thread. It led to install failure for me. The method worked well for the original poster, but removal of the old bearing was not possible for me, and I approached it a few different ways. Just my 2 cents.
http://www.xs650.com/forum/showthread.php?t=7201&page=2
Grab the angle grinder, cut through the old bearing BEFORE using it as a driver....
Too bad I didn't think of this sooner, the OP could have done that to the top of that bearing; cut a slot at an angle rapped the slot with a chisel, the rest of the race would crack through and it would have come right out. Common way to remove a sleeve or race stuck on a shaft.
Dang...good idea
Double dang. I was laying my grinder into it, didn't know that trick. Thanks though I'll file it away - hopefully won't need it for the redo! :bike:
The technique I used was to grind the outer face of the old bearing on a bench sander/grinder until it was a slightly smaller outside diameter. It could then be lifted out by hand after seating the new bearing.
you can actually go to most auto parts places nowadays and get tools on loan. Or an over the pond bearing driver set is around $30.
Well you have it out now but this idea may help others. Wind a dyna bolt (expandable bolt used for fixing to concrete) in the bearing you want to remove. Then drive the bolt out from the other side.
make sure that they have supplied the correct dust cup . I would compare your old with the new, for width.
There are two widths and I was supplied with the incorrect thicker dust cup for my 79 rear hub which completely jammed my wheel once it was all tightened up. :banghead:
I know you already have the bearing out but something that usually works pretty good is to weld something over the hole in the bearing, then put a drift thru the wheel from the other side and and then you can smack it out without touching the new bearing
Exactly what I was going to say hooligan.....many times I have welded a 5/8 nut to the old bearing and screwed in a 1ft pc of 5/8 all thread from the other side and tapped it out. This also works with bearings in blind holes.......... i just use it as a slide hammer and pull it out rather than push.
You guys are good. Thanks for sharing the tips and tricks of the trade, as a hobby guy I have a lot to learn.
Peanut - i also received the incorrect small grease cover. It was green and metal but s/b rubbery plastic and metal. After installing it I knew it was wrong so I had to blow that up too.
The pencil is pointing to the destroyed wrong cover. The original is on the right. I know I should have checked first! I'm usually not such a flipping hack, but hey I had a bad day :)
I rarely replace the grease seals. If you're careful with the removal you can just reuse them. The best way is not to remove them at all but rather let the bearing push them out as you drive it out.
