mortikan
- Messages
- 30
- Reaction score
- 0
- Points
- 6
so my bike sat for two years needing a new set of rings pistons and top end.
so finally I got the dough together to buy parts and got the old girl back together. she runs and sounds great. I try to put her into gear and she stalls.
I did put castrol gtx 20w-50 I think this might be the problem I have not had a chance to check.
but I start her let the bike warm up and on the center stand I can put it in gear and shift first through 5th. with me on it or with me off it while on center stand.
If I put it on the ground she goes into gear but as soon as I release the clutch she bogs till she stalls. I have adjusted the clutch like manual says with the adjuster. I removed the front caliper to make sure it was not front brake holding me up. I am going to undo the rear brake tonight just to verify it is not that.
I did not touch the bottom end of the engine and she was working perfectly before I had ring issue.
could it be the oil is to slick to allow me to engage? I am going to dump gtx tonight and get the penzoil I was running before. I am trying to eliminate the simple things before I pull the clutch. my thought is that if she goes into gear while on center stand then the plates are not sticking together. If she would not go at all I would assume sticking. maybe I am wrong not sure.
any help or suggestions are much appreciated.
