new parts showed and I wanted to install the tire sprocket and set the wheel aside. I needed longer bolts so up to the hardware store and picked up 5mm longer bolts. They were a 10x1.25 and I took an original with me just to make sure. Went to install the sprocket and last two bolts don’t want to go in. Switched a couple around and the problem wasn’t the hub, two of the six bolts were a 1.50 thread so back up to the hardware to exchange. Luckily it’s close. Took out the grinder today as well because it’s time to get this back together the right way. I cut off the brat tail leaving just a bit so I could grind down to where I needed to be. No sense in trying to get too close with a cutting wheel because that never turns out good for me..
I then cut the new frame section the same way, walking my grinds into the profile I needed. I still have just a fuzz of fitting to do and set a couple tack welds so I can go get this frame welded with a 220v machine.
View attachment 251293View attachment 251294
