Your cylinder barrels look very smart. Have you sprayed them with something? Mine are showing a little corrosion in places, especially behind the oil feed-line in front. They need to be treated with sometime.
Even though the clutch pushrod seal is the usual culprit here, the countershaft seal can leak like crazy too if that big nut holding the sprocket on has come loose. It needs to be really tight, like 90 ft/lbs, for that seal to work good. And even with that lock washer with the sides bent up, they still come loose.
Daniel - you do really nice work!
I'm comin' down tomorrow so you can do mine while I sit on my duff and enjoy the warm Arizona sun! I'll bring along the BEvERages and the All-Dressed Chips (I don't think you have that delicacy in the US).
Cheers,
Pete
