5T, that gentle head shake is EXACTLY what I experience with the 712 front in my TX650A. I'll likely replace them in a year or two.I use the 712 rears all the time but don't care for the matching 712 front. It's kinda "squirmy", giving a gentle head shake as I go through about the 35 to 40 MPH range. I guess I've grown used to it because I hardly notice it anymore, but needless to say, I won't be using one again.
I really like that stand and so far I’ve found Motion Pro sells nice quality stuff. Too bad I’m a bit too “Frugal” to own one of those.For what it's worth, the motion-pro stand works pretty well. And folds up for easy storage when not in use.
Oh the pressure… maybe I should buy an Amazon stand. lol. Yes to hot tires. When I planned to remove the tire this morning, I placed it in front of my diesel heater for a good hour before prying it off and the 29 year old rubber was quite pliable.If you can find, buy a cheap wheel balancer just do it.
https://www.harborfreight.com/motorcycle-wheel-balancing-stand-58738.html
once the heavy spot starts moving around that's good enough.
I know you and you'll get your money's worth out of it.
I have a fancy shmancy Coats manual MC tire changer in the SOIR but use 2x4s on the floor and tire irons in the winter. Cuz wood stove.
Can't over emphasize heat is your friend when mounting tires; a hot tire is an easy to mount tire.
Thanks @gggGary. I may order one tonight.I can sketch a cheap diy wheel stand won't even need bearings a welder would be nice make it easy to put together.
My tire balancing jig hasn’t arrived so I tried balancing my wheel on the axle, supported on both ends to level the shaft. I am getting erratic heavy and light spots on the tire and I figure it must be the bearings that are causing this. The bike was sitting for over 13 years do I think the bearings might have developed some “tight” spots, throwing off my attempts to balance the wheel.when holding up the axle with 2 jack stands, is the wheel bearing going to actually free move as well as the 2 bearings on a tire balancer like what gary shows?
I'd be worried that the condition of the wheel bearing would come into play there and not allow you to see the heavy spot as well.
I’ll try that. ThxWhy does the wheel have to be on the axle using the bearings as a pivot? Maybe try a smaller diameter rod which is both straight and has a smooth surface for the bearing inner diameter to settle anywhere without bearing resistance?
Yesdid yah put a bit of spit on the valve stem?
