TX750 swingarm
Roy
Colorado
Why are tx750 swingarms special? I have seen them mentioned several times in various posts. Thanks
Heavier construction.... . .. less twist. I believe slight longer... road race boys like them... Had one on a Special.... .. lower the front forks..one inch... bigger rear drum brake with th4e Tx.. all bolt on... bike handled very well.... a piece of cake to center stand it... 😎😎
Yes, the 750 swingarm is the same size (length and width) as the 650 one, but has one important difference - the tubes are about ¼" bigger in diameter. This makes it much stiffer and it's a simple bolt-in swap .....
There is one small issue you may encounter though. The 650 arm is dimpled on the side for clearing the brake pedal linkage .....
The 750 arm doesn't have this but usually just flipping the pin around that attaches the brake rod to the pedal bracket is enough to provide the needed clearance. You want the head of the pin on the inside, the cotter pin end facing out .....
Like I said, it's tight in there, but on both of the ones I installed, it did fit .....
If more clearance was needed, I had planned on bending the bracket out away from the swingarm a little, but I didn't need to.
Thanks to all for the information. Now I know. My xs1-b could use some help in the handling department that's for sure. When I owned my original back in 71, I didn't realize how bad the handling was.
Keep in mind, the TX750 also has a more rigid frame. There is a cross tube welded in near the swingarm.
The XS650 design is certainly different.
The swingarm upgrades look cool and I am sympathetic to doing them. I remain unsure if it actually gains anything.
XS650D frame
Maybe in the real world there is no difference. I won't pretend I'm an engineer.
I'm not sure the TX750 swingarm would fit an XS1. I think the early swingarms ('70-'73) are shorter, maybe narrower too, at least at the back where the wheel mounts. I think the pivot area is the same so it would fit there, I'm just not sure about clearance farther back. Maybe gggGary can help with this? He may have some loose early and late swingarms he could compare side by side.
Parts supplies are decreasing here-abouts.
yeah about everything on the early 70-73 frames is lighter flexier than the later 74 up parts.
:twocents: Don't know what your 71 is right now but if it's anywhere near stock leave it alone, aside from clearances, maint, bearings, bushings, etc. Lot easier to start with a later bike (78-up) for better handling.
No, I thought that.
I had to hunt down a '70 to '73 Swing Arm for the first XS1 frame that I bought, despite having a fair pile of '74 onwards ones.
IIRC the width is the same at the front, but the 74 arm is longer and wider at the axle end.
And the shock mounts are further apart too.
So the TX750 might still be possible, but with a few modifications
Yes, the TX750 arm makes the perfect "sleeper". You can't really even tell it's been changed and is different unless it's parked next to a 650 with the stock swingarm.
I've swapped one into both of my (later) 650s. It made a real difference on my '78 Standard, not as much of one on my '83 Special. I'm thinking the slightly more laid down rear shocks on the Special triangulate better and make for a stiffer swingarm to frame configuration.
I fitted aTX750 s/arm to my 1978SE. The housing for the torque arm had to be relocated from under to on top of the r/h arm, and the chain guard attachment needed adapting on the l/h arm. I can't really claim it has transformed the handling, my seat of pants hasn't really noticed much difference.
Hello! Long time lurker but just signed up and am excited to be a part of this group. Can someone tell me what the tube diameter is on a tx750 swingarm? I know this is a bit of an old thread but I looked around and couldn't find this information (sorry if I missed it) and thought it would be helpful if it was included here. I purchased what was said to be a tx750 swingarm but it looks the same as the swingarm on my 1977 xs650 (which I am 99% sure is factory). My swingarm has 34mm diameter tubes. If no tx measurements could someone confirm that's factory for the xs650?
Hi @jacobb90 and welcome to the madhouse. I did the conversion so just been out to garage and measured. With my rusty old cheapo caliper the XS swing arm has a diameter of 34mm and the TX item 38mm. Both approximate. Also, the torque arm housing is different and I had an engineer move it from under to over - easy to do yourself if you have a welder? Also, the chainguard mount is different but easy to sort.
