1. Dismiss Notice
    Dismiss Notice
What the Heck Is It ?
Discussion in 'The Lounge' started by YamadudeXS650C, Dec 22, 2017.
  1. Jim
    I believe they're ejected overboard.
  2. YamadudeXS650C
    YamadudeXS650C Central New York XS650 XS650.com Supporter Top Contributor
    Hint: This professional tool would see limited use here in Upstate New York during the month of January.
    Paul Sutton and Jim like this.
  3. Wingedwheel
    Wingedwheel Outsmarted myself once again XS650.com Supporter
    I see what looks to be a warming pan on the bottom?
    Paul Sutton likes this.
  4. YamadudeXS650C
    Nope.
  5. YamadudeXS650C
    This might be a give-away.
    Here is a closeup pic of the bottom part.
  6. YamadudeXS650C
    Reveal:
    It is a vintage ('70's ?) Robinair Dial-A-Charge Cylinder, used in automotive (by my car mechanic neighbor) and other HVAC applications to transfer bulk refrigerant to smaller cylinders. I've only seen one other a few years ago in a Syracuse used building materials store.
    Some of them actually did have a heater at the bottom, but not this model.
    ROBINAIR Dial-A-Charge® Charging Cylinders
    [​IMG]
    Calibrated shrouds make accurate charging simple, and the charge is measured by weight for greatest accuracy.
    Using the calibrations in conjunction with the pressure gauge, you can easily compensate for volume fluctuations that occur as the ambient temperature changes, just by “re-dialing” the shroud.
    Heated cylinders help speed the transfer of refrigerant by overcoming the equalization of pressure between the system and the charging cylinder. This reduces the time required for a complete charge.
    • Allows systems to be charged quickly, with the precise amount of refrigerant required by the manufacturer
    • Simply “dialing” the shroud to correspond with the pressure gauge, allows you to compensate for any ambient temperature changes
    • Sight glass allows you see the level of refrigerant in the cylinder
    • Accurate charging eliminates call-backs caused by under or over-charging
    • Cylinders may be economically filled from a bulk tank
    • Includes Heater, to increase cylinder pressure and speed refrigerant transfer
    • For safety, all cylinders are equipped with pressure relief valves, which automatically reset once a safe working pressure is restored
    • Includes a durable Polyethylene Case
    • Made in USA
  7. 59Tebo
    59Tebo 59Tebo Top Contributor
    ...and so far, it wouldn't see much use around here in May either....
    gggGary, GLJ, Mailman and 2 others like this.
  8. Paul Sutton
    Paul Sutton Pipis Cooked on Corrugated Iron Top Contributor
    So 2M was basically right when he said:
  9. YamadudeXS650C
    Yes, the air in this area could be regarded as being a "refrigerant" :laugh2:
    TwoManyXS1Bs, 59Tebo, gggGary and 2 others like this.
  10. Mailman
    That was interesting! I thought for sure it was some antique. Cool garage art there brother!
  11. YamadudeXS650C
    Stopped at a couple of the 100 or so garage sales I passed on the way to the mountains on saturday.. Picked up a couple items for 50 cents each. Here is one of them. "Made In England" by "Superior", heavily built.
    6" long
    Some sort of tubing cutter?
    Leather working tool?
    The punch is hollow, but doesn't seem to be tooled to be a leather punch.
    gggGary, Paul Sutton, Mikey and 2 others like this.
  12. Grimly
    Grimly XS650 Addict Top Contributor
    354
    1,116
    143
    Ireland
    Jim and YamadudeXS650C like this.
  13. YamadudeXS650C
    I like their sales pitch, "Get a Grip".
    Jim likes this.
  14. RustiePyles
    RustiePyles Semper Fortis XS650.com Supporter Top Contributor
    Those are for fastening round leather sewing machine belts, have a pair just like em somewhere.
    Mailman, YamadudeXS650C and gggGary like this.
  15. YamadudeXS650C
    Mailman likes this.
  16. RustiePyles
    Yeah you got a good deal on a vintage one, the blade cuts the belt, the punch is used to punch the ends for a ring and the flat nose is used to crimp the ring. Also used on some older small lathes like watch maker and jewelers lathes.
    YamadudeXS650C and Mailman like this.
  17. RustiePyles
  18. Mailman
    Wow, that was an obscure tool.
    RustiePyles and Paul Sutton like this.
  19. YamadudeXS650C
    Cool video!
    RustiePyles likes this.
Share This Page
