yamchop
i'm going to finally buy a welder. just wondering what will work for building bikes. i only have 110 volt to my garage. any help would be great.
Since I have a strong feeling that the big name welders (Lincoln, Miller and Hobart) are all outsourcing to the same Chinese outfits, I wouldn't worry too much about name... just make sure consumables are easy to get, and parts are available.
The back of mine says, "Assembled in Mexico", not that it's any better.
On yeah.. Make sure that circuit in your garage is good for at least 20 amps or you're going to blow the breaker all the time. You're only going to be able to weld up to about 1/8" plate with one pass, maybe just a bit more. That's enough for pretty much everything you'll ever do on a motorcycle.
If you have money to burn and are committed to sticking to 110v, get this http://www.amazon.com/Miller-907335-Millermatic-Auto-Set-Welder/dp/B001VXWHKG
If you're broke, get this: http://www.amazon.com/Clarke-WE6523-120-Volt-Fluxcore-Welder/dp/B0008JHB5A
